| | Drenalin LD Cams 65% Let-Off | |
| Part# | Cam | Drenalin Draw Length | RH or LH |
| 12900A | CAM D-AR 65% 30R DL31R ASY | 31" | RH |
| 12902.5A | CAM D-B.5R 65% 29.5R DL30.5R ASY | 30.5" | RH |
| 12902A | CAM D-BR 65% 29R DL30R ASY | 30” | RH |
| 12904.5A | CAM D-C.5R 65% 28.5R DL29.5R ASY | 29.5” | RH |
| 12904A | CAM D-CR 65% 28R DL29R ASY | 29” | RH |
| 12906.5A | CAM D-D.5R 65% 27.5R DL28.5R ASY | 28.5” | RH |
| 12906A | CAM D-DR 65% 27R DL28R ASY | 28” | RH |
| 12908.5A | CAM D-E.5R 65% 26.5R DL27.5R ASY | 27.5” | RH |
| 12908A | CAM D-ER 65% 26R DL27R ASY | 27” | RH |
| 12910.5A | CAM D-F.5R 65% 25.5R DL26.5R ASY | 26.5” | RH |
| 12910A | CAM D-FR 65% 25R DL26R ASY | 26” | RH |
| 12901A | CAM D-AL 65% 30L DL31L ASY | 31" | LH |
| 12903.5A | CAM D-B.5L 65% 29.5L DL30.5L ASY | 30.5" | LH |
| 12903A | CAM D-BL 65% 29L DL30L ASY | 30” | LH |
| 12905.5A | CAM D-C.5L 65% 28.5L DL29.5L ASY | 29.5” | LH |
| 12905A | CAM D-CL 65% 28L DL29L ASY | 29” | LH |
| 12907.5A | CAM D-D.5L 65% 27.5L DL28.5L ASY | 28.5” | LH |
| 12907A | CAM D-DL 65% 27L DL28L ASY | 28” | LH |
| 12909.5A | CAM D-E.5L 65% 26.5L DL27.5L ASY | 27.5” | LH |
| 12909A | CAM D-EL 65% 26L DL27L ASY | 27” | LH |
| 12911.5A | CAM D-F.5L 65% 25.5L DL26.5L ASY | 26.5” | LH |
| 12911A | CAM D-FL 65% 25L DL26L ASY | 26” | LH |
| | Drenalin LD Cams 80% Let-Off | |
| 12800A | CAM D-AR 80% 30R DL31R ASY | 31" | RH |
| 12802.5A | CAM D-B.5R 80% 29.5R DL30.5R ASY | 30.5" | RH |
| 12802A | CAM D-BR 80% 29R DL30R ASY | 30” | RH |
| 12804.5A | CAM D-C.5R 80% 28.5R DL29.5R ASY | 29.5” | RH |
| 12804A | CAM D-CR 80% 28R DL29R ASY | 29” | RH |
| 12806.5A | CAM D-D.5R 80% 27.5R DL28.5R ASY | 28.5” | RH |
| 12806A | CAM D-DR 80% 27R DL28R ASY | 28” | RH |
| 12808.5A | CAM D-E.5R 80% 26.5R DL27.5R ASY | 27.5” | RH |
| 12808A | CAM D-ER 80% 26R DL27R ASY | 27” | RH |
| 12810.5A | CAM D-F.5R 80% 25.5R DL26.5R ASY | 26.5” | RH |
| 12810A | CAM D-FR 80% 25R DL26R ASY | 26” | RH |
| 12801A | CAM D-AL 80% 30L DL31L ASY | 31" | LH |
| 12803.5A | CAM D-B.5L 80% 29.5L DL30.5L ASY | 30.5" | LH |
| 12803A | CAM D-BL 80% 29L DL30L ASY | 30” | LH |
| 12805.5A | CAM D-C.5L 80% 28.5L DL29.5L ASY | 29.5” | LH |
| 12805A | CAM D-CL 80% 28L DL29L ASY | 29” | LH |
| 12807.5A | CAM D-D.5L 80% 27.5L DL28.5L ASY | 28.5” | LH |
| 12807A | CAM D-DL 80% 27L DL28L ASY | 28” | LH |
| 12809.5A | CAM D-E.5L 80% 26.5L DL27.5L ASY | 27.5” | LH |
| 12809A | CAM D-EL 80% 26L DL27L ASY | 27” | LH |
| 12811.5A | CAM D-F.5L 80% 25.5L DL26.5L ASY | 26.5” | LH |
| 12811A | CAM D-FL 80% 25L DL26L ASY | 26” | LH |
