-50%
49.99 € 99.99 €
 [CO] Doinker
[CO] Doinker Empty
MessageSujet: [CO] Doinker   [CO] Doinker EmptyMar 17 Oct 2006, 14:52
Comme je vais bientot recevoir ma nouvelle stabilisation, j'en profite pour répondre a certaines questions qui reviennent souvent. On peut consulter le FAQ du site Doinker dont voici un extrait:
13.WHAT IS THE DIFFERENCE BETWEEN THE D2, STANDARD, AND THE A-BOMB DOINKER?
A: The D2 has much less central mass so it must be harder than the A-bomb or Standard Doinker to be able to hold the weight level.
Because of the added mass of the A-Bomb the hardness can be 10 to 20 points less than the D2 and 5 to 10 less than the Standard Doinker, which relates to a softer feeling shot. In general the A-Bomb gives a softer feel and the D2 gives a feeling of more control. The standard Doinker is between the D2 and the A-Bomb in hardness and is a good middle ground for both target and hunting. The A-Bomb is the softest, the Standard is in the middle, and the D2 is the hardest
in order of the way the shot feels. The D2 has the most control because of the added stiffness.
15.WHAT LENGTH OF STABILIZER DO I NEED?
A: If you are a target shooter, most use somewhere between 24 to 30 inches for freestyle and 11.5 for Bowhunter Freestyle. The length per discipline aside, stabilizer length is totally dependant on the shooters style and how he or she wants there balance point to be. Years ago most shooters liked the bow to be weighted forward by a substantial amount, today most top shooters want the bow to dip slightly forward after the shot, but want the stabilizer system to be of lighter mass than past years. This is true of compound shooters and very true with recurve shooters. Length of stabilizer can be chosen on the type of envirnment you are shooting in also. If the conditions are windy you might want a shorter stabilizer with less wind resistance as an example.
Hunters usually use a stabilizer in the 2-7 inch range as stabilizers of longer lengths get tangled in the brush and can be a problem in the stalk. Todays reflex risers tend to favor the shorter lengths as the bow by itself will tend to fall forward on shooting. In hunting it is a trade off between actual stabilization, shock reduction, and balance.
10.WHAT ARE THE STABILIZERS MADE OF?
A: The long stabilizers, V-Bars and the 3D Carbon Stabilizer use uni-directional carbon fibers with a carbon weave top coat.
Our 4 Inch Shorty Hunter and 7 Inch Hunter stabilizers use steel inserts and use injected molded ABS glass filled outer shell for looks as well as durability.
The weights have a 5/16x24 hole at the distal end so additional stack weights may be added.
These units use the standard 3/4" Doinker.
The 5" Armored Hunter is totally encapsulated in elastomer and uses the same Doinker Technology as the rest of our line.
This stabilizer has a 5/16x24 hole tapped at the weighted end so additional stack weights may be added.
All caps and accessories are made from 6061 T-6 Aluminum and are anodized.
Pour ceux qui veulent en savoir plus, voici le lien:
http://www.doinker.com/faqs.php
aurore
Modérateur
aurore
Matériel : GMX / 990TX
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMar 17 Oct 2006, 18:04
j'ai rien compris Rolling Eyes Crying or Very sad
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMar 17 Oct 2006, 18:08
Oui je savais que tu allais dire ca...Trop la fleme de tout traduire.
Matt82
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMar 17 Oct 2006, 20:04
ta pas la version francaise mdr ???
on aurai ptet pas la flème de le lire
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMar 17 Oct 2006, 20:06
Si vous écoutiez un peu plus les cours d'anglais vous ne demanderiez pas la traduction. Razz
alexvpaq
alexvpaq
Masculin Nombre de messages : 817
Matériel : Hoyt Hélix+M1+Beiter longrod INFERNO!!!
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMer 18 Oct 2006, 01:09
lol! Les mecs désolé mais malgré ma bilingueté...
Je traduirai pas lol!
PS [CO] Doinker Logo_bei
http://archery-online.1fr1.net/
aurore
Modérateur
aurore
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyMer 18 Oct 2006, 13:20
hey, ça ne sa fait pas ... moi je comptais sur toi ! Neutral allez, un petit effort stp (moi, je vient de me prendre un 4/20 à mon dernier DS d'anglais alors ...)
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 12:02
C'a y est j'ai ma Doinker. Tres content! Very Happy
aurore
Modérateur
aurore
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 17:58
photoooooooooooooo ???? [CO] Doinker Saut1
alexvpaq
alexvpaq
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 18:31
triste que sa marche moin bien que beiter Rolling Eyes lol!
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 18:45
Triste surtout de voir que Beiter c'est de la merde a coté de ca. Maintenant que j'ai essayé Doinker, toutes les stab du monde deviennent inutiles, j'ai trouvé la meilleure
aurore
Modérateur
aurore
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 18:49
d'ailleur Maxence .... j'attend mon colis avec ton ancienne beiter dedans Exclamation
merci beaucoup Cool
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 19:15
Mais tu vas nous dire que tu tires avec ta beiter, même si doinker c'est mieux (comme tu dis que matthews c'est les meilleurs.......)
alexvpaq
alexvpaq
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 22:31
surement l'année prochaine Twisted Evil
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptySam 04 Nov 2006, 23:09
Non je garde la Doinker. Elle m'a vraiment convaincu
alexvpaq
alexvpaq
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyLun 06 Nov 2006, 00:13
ok mais le choix dcouleur est pas aussi bon que chez beiter par contre Razz lol!
DuDu
DuDu
Masculin Nombre de messages : 1920
Matériel : Hoyt recurve Helix
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyLun 06 Nov 2006, 12:23
Oué mais ça sert à rien d'avoir le choix si tu reçois jamais tes caches de couleurs lol!
Allé Alex fait pas la tete :p
aurore
Modérateur
aurore
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyLun 06 Nov 2006, 17:05
je connais plusieur personnes dont les caches se pète sans raison apparentes ... c'est un petit peu fragile ces machins !! Razz
alexvpaq
alexvpaq
[CO] Doinker Empty
MessageSujet: Re: [CO] Doinker   [CO] Doinker EmptyLun 06 Nov 2006, 22:05
ouai il devrait arrivé cette semaine...
dumoin j'espere...
Mad
[CO] Doinker Empty
[CO] Doinker
» Doinker pee wee
» Stabilisation Doinker
» Doinker 2010
» Doinker Platinium
» Doinker 2010
